CC Racing Engine Mounts
Scott created the topic: CC Racing Engine Mounts
** This thread discusses the Content article: CC Racing Engine Mounts **
These look VERY close to the original Hyper Torque mount.
Could you share what the Center Line of AV mount stud is between the front and rear mount tabs ?
Nice product, would love to have them interchange with the Original mounts of this design.
It is GREAT to see CC racing recreating the quality of the original.
So many other copies threw the years have been garbage.
Scott
#3266
marc replied the topic: Re:CC Racing Engine Mounts
Scott,
As noted in the article, the mounts are a direct replacement for the Hypertorque style mounts...NOT the composite or Bonzi style. Measurement seems to be about 5 3/4 inch... I will have to pull an engine from one of my boats to measure exactly and let you know for sure. I do know that CC Racing Engines had received permission to produce and improve on the Hydpertorque mounts, which is how these wore born. :)
#3267
Roxyflash replied the topic: CC Racing Engine Mounts
Are these thicker mounts than the original ones CC Racing Had?I had stripped the front plate on one screw and broke one rear mount.I do like the style on these mounts.
#3272
INEEDSPOTS replied the topic: Re:CC Racing Engine Mounts
CC style mounts are all ive used since i got into gas boats...and have only broke 2 standard rear mounts. Ive found that they only break when you have to squeeze them between the lord mounts to get the motor in. Somehow it seems that the mounts sometimes end up being a little wider or something...as ive had them that fit nice and easy into the boat, and others that had to squeeze.
#3273
